Canon ImageFORMULA DR-G2110 SMB settings not showing
NFolk
Hi all,
I recently purchased a Canon ImageFORMULA DR-G2110 (with LAN connector) as everything I was seeing said it could scan documents to a network server folder without needing a computer attached. When I look it up I am told to go into the web portal and assign the scan folder pathway and credentials in that SMB tab. When I connect to the IP web portal I do not get any options for remote scanning.
Is there something I am missing that would enable this setting? Or was I wrong in thinking this scanner could scan to a network folder without needing it attached to a desktop?
1 REPLY 1
Scan to Network Destination can be performed without a computer after the scanner is set up and configured on the same network as the storage location. It includes One Touch functions that can be configured using the capture on touch software.
