imageCLASS MF753Cdw II- why the settings or software is showing MF750C II ?
sritco
Hi, A new color printer .. original; invoice, box and printer showing imageCLASS MF753Cdw II;  But when I initial set the printer.. on the config, on the WIFI, on the network.. and on the OS App: "Cannon Print"  :   the name appears as:
MF750C II Series
Ok, I might not freak out for a digit.. but.. the online manual and settings are differing ( ex: System manager vs Administrator ID etc )
Did I missed step? wrongly initial setup ?
How can I verify that my printer is 753Cdw II and not 750C ?
Thanks
You're fine. This is normal.  It displays the series not the actual model.  😉
3 REPLIES 3
sritco
Thanks;
I'm trying to scan from the printer to Email or Folder - I got #806 error ( file trf) and #801 error on email; I do my research, manual, blogs etc;  but not able to pass that;  I' m using a MAC as computer ;  is there something friendly ( doc or video) to show that part - how to configure or troubleshoot connection : for Scan to Email, or Scan to Folder  -  using WiFi ? I and yes, I'm on the same wifi (SSID)
Thanks
Have you set up access to the remote UI?  You'll need to be able to log in as a System Manager in order to configure scan to email & scan to folder.
If you can tell me which mail host you're using I can help with those settings too.
Here's an example I made using Gmail.
https://community.usa.canon.com/t5/Office-Printers/imageCLASS-MF753Cdw-error-2100009-not-scanning/td...
