MF741C: Setting up Scanning to E-Mail
Duke_of_Zork
I'm trying to configure a Canon MF741C to scan to e-mail, and the manual is unclear. I found the place in the Remote UI where you're supposed to do the configuration.  The manual says:
[SMTP Server]
Enter alphanumeric characters as the SMTP server name (or IP address) for sending e-mail and I-Faxes.
[E-Mail Address]
Enter alphanumeric characters for the e-mail address that you want to use for the machine.
Which alphanumeric characters is it asking for? And what e-mail address?  Is it asking for my personal e-mail settings (this didn't work), or something else?  Or what IP address?  The printer's IP on the network (192.168.1.33)?
There are also some greyed out fields, including the one for POP Server, User Name (Fixed at the ID I set up for the printer), and Set/Change Password (fixed as the Pin# I set for the server).
5 REPLIES 5
You'll need to supply the SMTP server address of the mail service you are using for relay.
The email address is the username or email address  for the account you are using to authenticate.
Example M365
Device or Application setting Value
Server/smart host smtp.office365.com
Port Port 587 (recommended) or port 25
TLS/StartTLS Enabled
Username/email address and password Enter the sign-in credentials of the hosted mailbox being used
Hint, if you use Gmail, create an App Password.
~R5 C (1.0.7.1) ~RF Trinity, ~RF 100 Macro, ~RF 100~400, ~RF 100~500, ~RF 200-800 +RF 1.4x TC, BG-R10, 430EX III-RT ~DxO PhotoLab Elite ~DaVinci Resolve Studio ~ImageClass MF644Cdw/MF656Cdw ~Pixel 8 ~CarePaks Are Worth It
That doesn't work.  I've got an AOL e-mail address.  So, I've got it set at:
SMTP Server:  smtp.aol.com
E-Mail Address:  [my e-mail address]
POP RX:  Off
Authentication/Encryption Settings
POP Authentication Before Sending:SMTP Authentication (SMTP AUTH):Use TLS for SMTP:Use TLS for POP:
Off
Off
Off
Off
And when I try to scan something and send it to my e-mail address, it prints off an error sheet:
TX Result Report
Job Number:  0001
Start Time:  [the time the job was tried]
Sheets:  0
Error:  [my e-mail address]
I found this doing a quick Google Search.  It appears AOL also requires that an app password be created.  I don't have AOL so I have not verified this.  Instruction should be available in your account.
I must be on the wrong screen then, because I don't see most of that.  Here's what I've got:
Thats correct.  you're not.  The printer has a complex feature set.
Configuring E-Mail/I-Fax Communication Settings - Canon - imageCLASS MF746Cdw / MF745Cdw / MF743Cdw ...
Please read this entire section, the instructions for changing the port at near the bottom.  Note, the printer has to be restarted after the settings are completed.
See this as well for additional assistance:
Create and manage third-party app passwords - AOL Help
Looks like you are pretty close 😀
Avatar
