imageCLASS MF634Cdw - The blue color drips dots now on all printed materials.
majag
Trying to troubleshoot this laser printer.  The blue color drips dots now on all printed materials.  Already did the two types of cleanings:  Clean Fixing Assembly amd Clean Feeder.  Clean ITB button refuses to start, so we are unable to get that going.  Does ceylon blue tomer cartridge need changing periodically?  It is leaving crumbly blue bits all over inside the machine now after the two cleans.  Tried to remove the 3 cartridges and leave black inside only, but there must be a sensor telling the printer not to function due to the 3 missing cartridges.  And naturally, the 3 years warranty just expired.  Thanks in advance.
9 REPLIES 9
normadel
You mean CYAN cartridge, not "Ceylon", right?
Is this a genuine Canon cartridge, or is it an aftermarket (non-Canon) cartridge?
Sorry, iPad typing at its finest.  Yes, CYAN.  It’s blue and leaving powder bits all over the paper being printed, polka dots and inside the laser printer itself.  Any idea why this is happening and what troubleshooting I can do that I haven’t tried already?  TIA.
PS. And yes, it is a genuine Canon cartridge.
normadel
It sounds like you have a leaky cartridge that toner is just falling out of.
Compare it to one of the other cartridges to see if it looks different in the area where toner comes out. Something ajar, broken, loose.....
Hector
Hello Majag,
The issue you are describing would usually mean the toner is not seated properly or it is damaged and leaking. You can try removing all of the toner cartridges and checking the inside of the printer for any loose toner powder that you can wipe up with a damp cloth or you can try replacing the cyan cartridge to see if it resolves the issue.
If it continues to have issues, it would mean the printer needs service. You can log into your MyCanon account to view any available service options.
Thank you for your suggestions!
Thanks for your help!
Im also having issues. i have all genuine new toner cartridges, but when i try to print, my image seems to be missing some colors to it. not severely but you can tell the picture doesn't look quite right.. like its missing the magenta toner to the image... so i tested it my printing a simple tie-dye / rainbow image and sure enough its missing some color.. i have factory reset, because i tried to perform a correction but it says that it cant perform the correction, and ive tried the other style of correction. my drivers and firmware are all up to date, and im just kinda frustrated spending over $300 on toner if i cant even use it. any help would be appreciated!
You need to start your own separate topic. Your problem has nothing to do with THIS topic, and will not get attention in the listing of topics.
Holiday
EOS C400 - Version 1.0.4.1
EOS C80 - Version 1.0.4.1
XF605 - Version 1.0.7.1
EOS R3 - Version 2.0.0
EOS R1 - Version 1.2.0
EOS R5 - Version 2.2.1
EOS R7 - Version 1.7.1
EOS R10 - Version 1.7.0
EOS R8 - Version 1.5.0
EOS R50 - Version 1.4.0
Powershot V10 - Version 1.4.0
Powershot V1 - Version 1.1.0
EOS R50V - Version 1.1.1
