03-17-2025 06:14 AM
Nearly new Maxify GX6050 has problems printing yellow - the ink pipe from the tank to the print head is full of bubbles (more bubbles than ink). I use colour printing only intermittently. I've already run several Nozzle Checks and a couple of Cleaning and Deep cleaning cycles - the maintenance tank is half full. All ink tanks over half full, printer has only printed 300 pages.
The web is full of ideas for using a syringe to suck out the air - is this the right thing to do?
Thanks for any advice.
03-25-2025 05:44 AM
The solution to this problem ( from Canon-UK chat) is to perform an Ink Flush (not nozzle cleaning or deep cleaning). That's well down the maintenance menu. It drinks ink and you end up with a maintenance cartridge nearly full so have bought a not-cheap replacement. But printer on top line again.
Thanks
03-19-2025 08:24 AM
Welcome to The Canon Community, and thank you for your inquiry!
We appreciate your participation, however, we need to let you know that the Canon Community is hosted and moderated within the United States by Canon USA. We are only able to provide support for Canon products manufactured for and used within the US market.
If you live outside the United States, please CLICK HERE and select your country or region for your support needs.
You're welcome to discuss Canon products sold outside of the United States, but please be aware that you will not receive support directly from Canon USA.
03-25-2025 05:44 AM
Thanks
