11-26-2018 04:34 PM
On occassion, I need to copy something and need the copy to be as close to the original in size as possible. I imagine I can mess with the scaling options but am wondering if there is a way to permanently 'calibrate' the size of the copied image instead of having to go thru a trial and error period when I need precision.
Thanks,
Mike
11-29-2018 11:17 AM
Hi weightdn!
You can set the printing ration in the Function settings of the printer. Please follow the steps below directly at the machine:
(Menu) => (Function Settings) => (Copy) => (Change Default Settings (Copy)) => (Copy Ratio) => (100% Direct) => (Apply)
You can also view the steps at this link:
If you still continue to experience an issue, please call us at 1-800-OK-CANON (652-2666), Monday - Friday 10:00 a.m. to 6:30 p.m. ET (excluding holidays).
11-29-2018 11:17 AM
Hi weightdn!
11-29-2018 05:02 PM
Thank you Patrice. I will give that a try. Also, I found that most of the problem was the operator. After looking again, I noticed that part of the test image had been clipped. I had placed the image against the edge of the scan area and a small portion of the image was clipped. Things came out much better when I moved the source away from the edge of the scan area. Hopefully that will get me 'close enough'.
Thanks again,
Mike
