11-28-2018 08:23 PM
please, help me!
currently, i can't use scan function on canon mf4800. it's an error message with code 155. i reinstall driver but it doesn't working and i use canon toolbox to scan.
thanks, everyone!
11-29-2018 11:43 AM
Hi kikimacho.
I will be glad to assist you. However, I will need to ask a few questions, so that I can best assist you. Please answer the questions below:
1. Which version of Windows is installed on your computer?
2. Is the printer connected to the computer with a USB cable, or wirelessly over the network?
I look forward to your response.
11-29-2018 08:32 PM - edited 11-29-2018 08:37 PM
Hi Patrice
i'm happy when you support
. I will answer your questions as follows:
1. Currently, i using windows 10 64bit and i try to installed printer on windows 7 professional 32bit. I get the same error.
2. Printer connected network cable. i checked the network everything normal
11-29-2018 11:43 AM
Hi kikimacho.
Hi Patrice
