PIXMA MX922 Scanner Utilities won't install
spenglertp
I recently purchased a new PC with Windows 11. When I try to install the OEM drivers for my Canon PIXMA MX922 printer, the following error displays: "An error occurred while files were being copied. : 0305 0036". As as result, the Canon drivers for the scanner utilities won't install. What does the error code signify, and how can I overcome it?
2 REPLIES 2
DerrickL
Since your pc is new make sure Windows is not in S mode, if it is it will not allow you any installations except from the Microsoft Store.
Steps to Disable S Mode in Windows 11
To switch out of S mode in Windows 11, follow these simple steps:
Access Activation Settings
  1. Open Settings on your PC.
  2. Navigate to System.
  3. Click on Activation.
Switch Out of S Mode
  • Look for the section labeled S mode.
  • Click on Go to the Store.
Complete the Process
  • In the Microsoft Store, follow the prompts to confirm the switch.
  • After confirmation, you will be able to install apps from outside the Microsoft Store.
Important Notes
  • Switching out of S mode is a one-way process; you cannot revert back to S mode once you make the switch.
  • There is no charge for switching out of S mode.
I followed your instructions. There is no section labeled S mode.
