03-24-2021 07:30 PM
So, I need to scan a bunch of double sided docs on my mf4445dw. Is there a way/setting for this on the canon scan utility? Can't seem to find one. If I manually scan via the glass it will ask if I want to add pages. But via the feeder, it doesn't ask.
10-15-2021 05:19 PM
I am using Windows 10, and downloaded the latest MF Scan Utility from Canon's website. Your post got me thinking about utility versions, and I found the install CD (which I often don't use because it's out of date by the time I get it). I uninstalled the latest MF Scan Utility and installed the three year old one on the CD. The double-sided option is now there. Go figure.
Thanks for your suggestions!
Lisa
05-20-2021 01:12 PM
Hello mensan,
When scanning using the MF scan utility, you can set the scanner to perform two sided scans. In the MF scan Utility, you can click on settings in the lower right hand corner. In settings, you can click on the option for document scan. To the right you will see the option to select the source, you can click on that and select the duplex option for the auto document feeder. When scanning using the operation panel, you can select settings in the scan window and then you can switch the two sided original setting to on. When loading items into the auto document feeder, the scanner will not ask to load the next page, it will scan until it no longer detects any paper in the tray. If the two sided original setting is set to on, it will go through the loaded stack of documents and scan both sides.
10-09-2021 11:30 AM
I have this issue as well. Using the MF Scan utility, there is no setting for selecting a source. (Screenshot attached) Not sure where to go from here.
10-13-2021 05:54 PM
I compared your settings screen capture with mine- and yours does not display the 2-sided option (see my side-by-side screen capture). Is your MF Scan utility up to date- and are you using Windows 10? BTW, I am having other scanning issues - lack of connectivity with 3rd party scanners (VueScan) and usually have to restart Canon's own MF scan utility twice for it to find the scanner. I think the firmware in the device is buggy and at fault, so Canon needs to fix it..
10-15-2021 05:19 PM
Lisa
10-16-2021 12:59 AM
Glad that helped- but no clue why the old driver works better than the most recent : )
06-18-2022 07:22 AM
I am facing the issue with two sided scanning using the control panel on the printer. If we log into the remote UI we can turn on two sided scans to USB. But there is no way to turn on two sided scans to file. Please help.
06-22-2022 01:54 PM
I did not realize that 455dw scanned both sides at the same time. I assumed it was not getting the backside, until I looked at the output. I expected the unit to scan one side, pull the other side in again, and then recorded the scan. I am using Wireless. I was shocked when it also copied that way. I scan from the computer and had to check the box for two sided scanning. Old Guy
02-07-2023 04:10 PM
Hi, may I have the version of MF Scan utility, which got this two sided scan option available? Hope I can get that older version, somewhere from the WWW. Please advise,
Thanks, David
04-06-2024 10:15 AM
I do the same. But still, the option for both sides is not available. I use canon i-synsys 655 cdw printer. Is there any advice.
