MF 628cw how to scan multiple pages to one PDF file
tabalt2011
Hello,
I install MF Scan Utility Ver.1.9.0.0 on my laptop. Everytime when I scan documents from MF 628cw, they show on my laptop as separate JPEG format. how to scan multiple pages to one PDF file? Every time I need to convert them. It is annoying.
Thank you!
Tab
2 REPLIES 2
Start here:
Read the MF Scan Utility User Guide
See pag 16 - Scanning with customized settings
Then Pg 30-34 for settings customization options
Patrice
Whiz
Hi tabalt2011.
From the main MF Scan Utility window, select Settings:
Next, select Document Scan in the left column, and then click the drop-down for Data Format:
Verify that PDF is selected, and not PDF (Divide into Single Pages). Once you have confirmed that PDF is selected, click OK. Finally, click Document to scan the file.
If you are trying to set this option to scan from the Control Panel of the printer, please follow the steps at the link below:
Changing the Data Format Settings for the Operation Panel
If you continue to experience an issue, or require further assistance, please call us at 1-800-OK-CANON (652-2666), Monday - Friday 10:00 a.m. to 6:30 p.m. ET (excluding holidays).
