04-26-2019 09:52 PM
I have been using my D1320 for a couple of years and I love it. However, I did some maintenance (replaced rollers) because the paper was not feeding correctly and that works again but I also replaced the rollers and separation pad in the automatic document feeder and it no longer feeds. I was very careful and thought I put things back together properly but obviously I did something wrong. It makes the proper whirring sound but it won't pickup the paper. The rollers and separation pad look to be installed correctly so I'm at a loss.
Is there any documentation about how to disassemble and reassemble the document feeder? Any help would be greatly appreciated. I use(d) my ADF a lot and I'm about to replace this entire unit if I can't figure out what I did wrong.
Cheers!
04-27-2019
10:05 AM
12:31 PM
Tiffany
<removed per forum guidelines>
04-28-2019 03:26 AM
Thank you! I'll take a look and see if I can't figure out where I went wrong.
