06-21-2018 01:31 PM
Hello,
We just purchased a Canon imageCLASS MF733CDW and I cannot find how to set the machine to print a fax confirmation page after a fax is sent. Any help would be greatly appreciated!! Thanks!!
06-22-2018 04:12 AM
Hi ohcycle
Click HERE for instructions on setting the report option.
If you continue to have difficulties, please contact our support group using the following link:
http://Canon.us/ContactLI
06-22-2018 04:12 AM
Hi ohcycle
06-22-2018 09:13 AM
THANK YOU!!!! Totally missed the little option at the bottom that said output report when I was exploring things in the menu. I really appreciate your help!
02-06-2019 10:02 AM
Our company has a MF731C/733C and I cannot figure out how to make it print a confirmation page when we fax something. PLEASE HELP! thanks!
02-06-2019 10:14 AM - edited 02-06-2019 10:17 AM
Hi, fersa2019!
Thanks for posting! To be clear, does your company have the imageCLASS MF731Cdw, or the imageCLASS MF733Cdw? They're two different models. The model number can be verified by looking at the bottom of the front right of the machine.
If you need immediate help, our friendly, US-based support team is available by phone at 1-800-OK-CANON (1-800-652-2666) Monday-Friday 10:00am to 6:30pm ET.
02-06-2019 12:03 PM
it is MF731C/733C
02-20-2020 09:12 PM
I have ensured that everything is turned on "TX Result Report" every time I FAX in order to obtain a FAX confirmation; however, instead of getting a report, I keep getting a "report suspended," notification, so I wonder if the FAX is going through or not.
02-26-2020 01:21 PM
Hi, fersa2019 and SueCanon.
To fersa2019:
The menu map for printing a report after every fax (whether successful or not) is:
<Menu> <Output Report>
<Report Settings>
<Fax TX Result Report>
Select <On> or <Only When Error Occurs>
Select <Off> or <On>
<Apply>
To SueCanon:
What is the model number of the printer producing the "Report Suspended" error? Additionally, is the error accompanied by an error code?
04-06-2021 10:05 AM
I am getting the same error. everything was working. Then this error started. cannot print any fax confirmations. must delete the report. No one answers phone at Canon. If no solution will return to store, only had for two weeks.
05-26-2021 12:53 PM
Hello Larryrta,
The print jobs can suspended when the printer is out of paper or the paper settings are incorrect. Jobs can also be suspended when the printer is low on toner. If the printer is new, I doubt that the toner is the issue. In this situation, I would suggest trying to reload the paper or specifying the paper size and type using the steps in the link provided HERE. To assist further with the issue I would need some additional information. If you could reply to this message with the information below, we can further assist.
