imageCLASS MF733Cdw: Image Capture disappeared
DesertRatR
I have an MF733Cdw running on house WiFI. All equipment is Apple (Macs, iPhones, iPad). My mac is a mini 2023 (M2) running Sequoia 15.4.1. Everything was working just fine. I can print with no problem. However when I push Open Scanner button the Image Capture window has everything grayed out, even the three colored dots in the upper left corner. In the window it says No camera or scanner selected. Rebooting doesn't seem to work. This is a new problem. Suggestions?
12 REPLIES 12
DesertRatR
FYI, I did update the drivers to the 07/07/2025 versions. That did restire to colored dots to the Image Capture window, however no devices are listed
DesertRatR
The plot thickens. I removed the prnter and added it back. However it didn't add back the scanner, just the printer. ????
This might help.  Please download and run the installer.  Let us know the result.
Scanner Driver and Utilities v2.15.17
DesertRatR
No luck with the new driver. Since this happened after the recent macOS upgrade to 15.4.1 I am guessing Apple introduced some bug, and I will have await Canon to release a new driver for 15.4.1
BTW, the MF device has the latest firmware.
j3
I can't find the firmware, im on Mac, it
just updated to seq. 15.4.1 earlier today
DesertRatR
That is odd. I can't locate any drivers for that machine. They seem to have been pulled somehow. It reports "There are no results available for the macOS Sequoia v15. Please try again."
Firmware and all drivers for the MF733Cdw are available here:
Canon Support for Color imageCLASS MF733Cdw | Canon U.S.A., Inc.
They used to be. No longer. I tried both Safari and FireFox.
"3. Software and Driver Results 0 of 0 Results"
Friends and Family
