02-23-2018 08:20 AM
02-23-2018 08:50 AM
Hi, Alisha!
Thanks for posting on our forum! This community is designed for your fellow Canon owners to help each other out with any problems they may encounter. If this is a time-sensitive matter, search our knowledge base or contact our US-based technical support team at http://canon.us/SupportCF
Thanks and have a great day!
02-24-2018 01:30 PM
03-30-2018 01:04 AM
03-30-2018 03:25 AM
Hello, I still have no solution. I am convinced that it is a manufacturing fault. I have read in several places that there are people with the same problem and in the same space of time. It is a serious firmware failure but Canon will not respond. It has stopped working for me after only 50 impressions
03-31-2018 05:49 PM
05-04-2018 02:40 PM
Hello.
If the LCD display or menu is not responding properly, troubleshooting with our support group will be needed to narrow down the cause of your issue. Please contact our support group using the "Contact Us" link below for additional assistance.
07-07-2018 11:58 AM
07-07-2018 12:00 PM
07-09-2018 01:25 PM - edited 07-09-2018 01:27 PM
seems all they want is for me to spend another $90 which I'm stuck now cause I just spend $60 on more photo paper I can't use. And they tell me I gotta have it fix (like 6 months past warranty and this has been going on since 2011 at least. Fairly sure it's a firmware issue because they had one update for it last year. Too bad it wasn't a pushed firmware update. Wonder if it woulda made a difference. No excuse that a $20 refurbished Olympus P-10 that still works 15 yrs after I got it. but they don't make the pack for it anymore so I get the Canon and it lasts 1 1/2 years for $90 something doesn't add up (NEW !!!) used still works New it's a brick. At some point someones gonna get enough people together for a class action. 😞 Or Canon could do it the easy way. This isn't the Canon I grew up with that would bend over backwards to keep my business. You'd think their top priority is to have me keep buying their ribbon paper packs but apparently not...
Troubleshoot was hit the on button several times after I turned it off (and unplug the battery) I do see the screen is still there when I have a bright cree lamp on it. So I'd say way more than 5 times then turn it back on 10 min later if it doesn't work it's a service call and they won't tell me how much so $90 vs how much is the service?
