11-18-2018 02:15 PM
I'm feeling really stupid, and don't seem to be able to get my nice new EOS R to work with my samyang 14mm
I've got the camera set to manual focus, but can't get the shutter to work
Andrew
01-24-2020 02:14 PM
@Waddizzle wrote:
@Tvteacher60 wrote:Sorry, I'm a video shooter, do I have to go into my custom settings and change a specific thing?
Sorry, for the delay. Yes, you do. Or, you could simply not use C3 mode. Or, you could make the change, and then re-save the settings to C3, which is what I think is the best course of action.
I am saying make the change to "Release Shutter Without A Lens" setting, and then re-save to C3.
11-18-2018 02:35 PM
Your camera needs to be in either AV or M mode to use this lens.
11-18-2018 03:42 PM
11-18-2018 06:49 PM - edited 11-18-2018 06:50 PM
@andrew6071 wrote:
I've tried it in manual, I'll give it a go in av
Have a go at it in the camera menus, as suggested above. You just simply need to enable the camera to shoot without a lens.
11-19-2018 10:14 AM
"...to get my nice new EOS R to work with my samyang 14mm"
It's a Canon camera, probably best to use Canon lenses. Remember not being a Canon lens the camera doesn't know it is there.
03-10-2019 02:18 PM
01-24-2020 11:07 AM
It only works one time and I have to set it again to shoot without the lens again??? What am I missing????
Thanks,
Patrick Morrow
01-24-2020 12:32 PM
@Tvteacher60 wrote:It only works one time and I have to set it again to shoot without the lens again??? What am I missing????
Thanks,
Patrick Morrow
What shooting mode are you using? Custom shooting modes can be enabled to reset any settings changes you may make.
01-24-2020 12:36 PM
I am in the C3 Mode
01-24-2020 12:40 PM - edited 01-24-2020 12:43 PM
@Tvteacher60 wrote:I am in the C3 Mode
Just as I suspected. You are shooting in a custom shooting mode. That's the problem, then. Check the settings for your custom modes. The settings are being reset back to the C3 defaults as soon as the [meterIing] timer expires.
