EOS Webcam Utility Not Working on M1 Mac
chrisprotos
Hi All -
I've read all the threads and still can't get the EOS Webcam Utility working.
Any help would be much appreciated!
Here's what I have going on:
1. I'm on an Apple M1 Pro running macOS Ventura 13.4.1
2. Have a Canon RP with the latest firmware 1.6
3. Just installed the EOS Webcam Utility Pro v2.0
4. Have turned off wifi on my camera
5. Do not have the EOS Utility 3 running
6. Camera connected to my laptop with a USB C cable that I've tested as working. Camera screen showing the white laptop icon
7. Camera connected to external power source
8. Webcam utility and Zoom showing a "EOS WEBCAM UTILITY" screenshot below
14 REPLIES 14
jrhoffman75
Is this what you are using:
https://www.usa.canon.com/cameras/eos-webcam-utility
Hey John - yes, that’s the one.
jrhoffman75
Probably should contact Canon support then. Register your product (if you haven't already done so) and contact them.
Waddizzle
@chrisprotos wrote:
Hi All -
Try connecting the camera without an external power source.  If you are using a cable and port adapters, then try to use a cable that does not require a port adapter.
The Webcam Utility has two operating modes.  One mode is free, while the more advanced mode requires a paid subscription.  You select the operating mode by selecting the appropriate camera.
Hey Wadizzle - thanks for jumping in!
1. Tried with battery vs external power and getting the same issue.
2. I'm using a usb-c (camera) to usb-c (laptop) cable. And no luck. I also tried HTML mini (camera) to a video capture card to usb (laptop) - and no luck there.
I'm at my wit's end... maybe something in the Mac software or the RP software... are there any settings on either that I should check out?
Thanks so much for all the help,  y'all.
Chris
Tones
I'm having the exact same issue, the only difference is my camera (EOS 6D, with latest firmware). I've tried a couple different cables, no luck. On an older, Intel-chipped Mac, with the older version of EOS Webcam utility, it does work -- so I know it's a software problem. Following this thread, in case someone posts a solution that works.
mharrison
Sadly Canon is showing that they don't care about Mac support. I'm actually buying a different brand camera (as I write this) and thought I'd double check to see if Canon has changed it's ways.
If anyone is looking for a cheap M50, let me know. Very few photos were taken. Mostly used as a webcam until I switched back to Mac earlier this year and it has sat dormant....
mpena3
Have you tried using EOS Webcam Utility Pro 2.0.30 (macOS)? The website claims it is compatible with macOS Ventura. However, I'm a bit hesitant to update my Mac in case it doesn't work. Has anyone else tried it yet? I'd appreciate some feedback from others who have tested it.Screenshot 26-07-2023 20-50-10.png
Do you have a Mac with an Intel chip or an M1?
If you have an M1 chip, my experience is that it doesn't work. The software runs, but the signal from the camera doesn't appear. If you have an Intel chip, it may work.
