Can't get EOS M200 to work on EOS Webcam Utility on macOS Catalina 10.15.7
Scott4
Unfortunately, the latest operating system my MacBook Pro will support is Catalina. I purchased an m200 because it was advertised as being able to be used as a webcam, but I have never been able to get it to work. Every solution posted ad nausum has been tried and does not help.
What I need is previous versions of EOS Webcam Utility, or EOS Webcam Utility Pro, or a refund on the camera so I can buy a Nikon.
7 REPLIES 7
NatalyaP
Greetings Scott4,
Per review, the EOS Webcam Utility is not available for macOS 10.15 Catalina. The EOS Webcam Utility is available for newer Apple operating systems. Unfortunately, prior versions of the software are not available. For product return inquiries, you may reach out to our Sales Department for assistance. They can be reached at 1-800-385-2155 from Monday through Friday between 9:00 am to 9:00 pm ET.
Scott4
Can you please give the reason why you refuse to give us access to the older driver software we require?
The old version of the software was removed because it is not compatible with modern operating systems.
The EOS Webcam Utility Pro is not required to use your camera—it is live streaming software that enables you to use your EOS camera as a webcam.
The system requirements from the downloads page:
System Requirements
To use this software, your computer has to meet the following system requirements.
  1. Supported OS
    macOS (15, 14, 13)
  2. Supported Computers
    Macintosh with one of the above OS installed and a USB port as a standard feature
    CPU:
    - Intel Processors
    - Apple Silicon Processors
    RAM:
    - 2 GB or greater
  3. Display
    - Screen Resolution: 1,024x768 pixels or more
    - Screen Colors; Approx. 32,000 colors or more
  4. Supported Models
    EOS-1D X Mark III, EOS-1D X Mark II, EOS 5DS R, EOS 5DS, EOS 5D Mark IV, EOS 6D MARK II, EOS 6D, EOS 7D Mark II, EOS 90D, EOS 80D, EOS 77D/EOS 9000D, EOS Rebel T8i/EOS 850D/EOS Kiss X10i, EOS Rebel T7i/EOS 800D/EOS Kiss X9i, EOS Rebel T6s/EOS 760D/EOS 8000D, EOS Rebel T6i/EOS 750D/EOS Kiss X8i, EOS Rebel SL3/EOS 250D/EOS 200D II/EOS Kiss X10, EOS Rebel SL2/EOS 200D/EOS Kiss X9, EOS Rebel T7/EOS 2000D/EOS 1500D/EOS Kiss X90, EOS Rebel T6/EOS 1300D/EOS Kiss X80, EOS Rebel T100/EOS 4000D/EOS 3000D, EOS R1, EOS R3, EOS R5, EOS R5 Mark II, EOS R6, EOS R6 Mark II, EOS Ra, EOS R, EOS RP, EOS R7, EOS R8, EOS R10, EOS R50, EOS R100, EOS M6 Mark II, EOS M50 Mark II/EOS Kiss M2, EOS M50/EOS Kiss M, EOS M200, PowerShot G5 X Mark II, PowerShot G7 X Mark III, Powershot SX70 HS, Powershot V10
  5. Software size (Zip file)
    - 214 MB
If you need assistance with using your camera, or transferring the images or video from your camera to your computer, please contact support at 1-800-OK-CANON (800-652-2666).
jrhoffman75
Apple no longer supports Catalina, so you will probably be hard pressed to find other companies that support software or hardware compatible with Catalina.
I checked with a friend who has a Nikon. They told me that macOS 11 or higher is required; you might want to check that.
I have a canon 7d and I run I have the latest Mac, however the New EOS Utility does not show me where I can download my images. Also, in the previous EOS app, I was able to do a remote shoot where I can see the images show on my computer once I take a picture whilst connected using the USB. Now I do not know how to go about it. Can you help?
Greetings denzeltheheart,
The EOS 7D camera was designed to work with EOS Utility 2 but this software application is no longer supported and no longer updated for newer operating systems. Unfortunately, EOS Utility 3 will not function with this older Canon camera.
