06-28-2017 05:29 PM - edited 06-28-2017 05:30 PM
terribly sorry if this is a noob question, but I need to know if I am crazy or what. 🤦🏽♂️
Basically, in every picture I take, there is this annoying long triangular light on the top left corner of every picture I take and I wanted to know if this was a problem with the body(like if I dropped it or something), or dust in the lens,SOMETHING
please help. Thank you. Check the pictures to see what I'm talking about.
06-28-2017 06:31 PM
@liondog487 wrote:
Is that really the only thing it could be ?
Almost certainly. The shutter blades are cut diagonally, and when they don't open or close properly, you get that classic triangular shape. It's rare for a shutter to fail on a camera that isn't very old and hasn't seen hard use, but it happens from time to time. The good side is that a shutter failure doesn't require a lot of research that would add to the repair cost, and that it's unlikely to happen again. A T5i probably isn't so old that it's not worth fixing, but that's a decision you'll have to make. If you send it to Canon, they'll tell you what it will cost before you have to decide. And our experience is that if they fix it, it will be fixed right.
06-28-2017 05:36 PM
Pobably a broken shutter. You will need to send it back to Canon for repair.
06-28-2017 05:53 PM
06-28-2017 06:31 PM
06-28-2017 06:56 PM
06-29-2017 05:09 AM
A used T5i around $450. A shutter replacement should be around $220.
06-29-2017 09:59 AM
06-29-2017 10:41 AM
Then look at the T7i, it has dual pixel AF so it can do true AF during video. It also has an additional Video IS mode.
06-29-2017 10:42 AM
07-01-2017 06:13 PM
@liondog487 wrote:
The thing is I'm trying to be cost efficient and stuff. Honestly I think I should invest in a t6s body for the higher ISO, but my main preference is video. What do you think would be a better investment ?
