light in corner of every photo i take - canon t5i
liondog487
terribly sorry if this is a noob question, but I need to know if I am crazy or what. 🤦🏽‍♂️
Basically, in every picture I take, there is this annoying long triangular light on the top left corner of every picture I take and I wanted to know if this was a problem with the body(like if I dropped it or something), or dust in the lens,SOMETHING
please help. Thank you. Check the pictures to see what I'm talking about.Screen Shot 2017-06-28 at 5.26.08 PM.pngScreen Shot 2017-06-28 at 5.26.55 PM.pngScreen Shot 2017-06-28 at 5.27.12 PM.pngScreen Shot 2017-06-28 at 5.25.46 PM.png
@liondog487 wrote:
Is that really the only thing it could be ?
Almost certainly. The shutter blades are cut diagonally, and when they don't open or close properly, you get that classic triangular shape. It's rare for a shutter to fail on a camera that isn't very old and hasn't seen hard use, but it happens from time to time. The good side is that a shutter failure doesn't require a lot of research that would add to the repair cost, and that it's unlikely to happen again. A T5i probably isn't so old that it's not worth fixing, but that's a decision you'll have to make. If you send it to Canon, they'll tell you what it will cost before you have to decide. And our experience is that if they fix it, it will be fixed right.
Bob
10 REPLIES 10
kvbarkley
VIP
VIP
Pobably a broken shutter. You will need to send it back to Canon for repair.
liondog487
Bob
liondog487
Thank you so much ! Honestly was having the harder time trying to find out the issue but now I know.
A used T5i around $450. A shutter replacement should be around $220.
liondog487
The thing is I'm trying to be cost efficient and stuff. Honestly I think I should invest in a t6s body for the higher ISO, but my main preference is video. What do you think would be a better investment ?
Then look at the T7i, it has dual pixel AF so it can do true AF during video. It also has an additional Video IS mode.
https://shop.usa.canon.com/shop/en/catalog/camcorders
EOS 80D from the Canon Online Refurbished Store for the USA.
https://shop.usa.canon.com/shop/en/catalog/eos-80d-ef-s-18-55mm-f-3-5-5-6-is-stm-kit-refurbished
