01-29-2025 12:44 AM
My Canon EOS M50 is having flash issues, the in-built flash will only work if I flick open the flash before turning the camera on. If I then close the flash and re-open it or open it after turning the camera on at all, the flash busy icon appears and won’t let me take a photo. Photos both with (when working) and without the flash are coming out fine and there doesn’t seem to be a delay in the flash when it is working. Any idea what’s wrong and how I can fix it?
01-29-2025 04:46 PM
Please, any help would be amazing!
02-03-2025 05:44 PM
Greetings OR,
It's odd that the flash only functions when opening it prior to powering on the camera. Let's go ahead and try resetting the camera to see if this may help resolve the issue. Please review page 298 of 314 of the user guide for steps on how to reset the camera.
https://gdlp01.c-wss.com/gds/3/0300029803/01/eosm50-um-en.pdf
In case the issue persists, then there may be an internal issue with the printed circuit board (PCB) and how it communicates with the flash assembly of the camera. We would suggest on sending the camera to our facility for repair.
Canon U.S.A., Inc. has created a new online repair portal that allows you to set up service in a few simple steps. The repair portal gives you the ability to set up service for multiple pieces of equipment at once, and to receive a repair estimate in the majority of cases, depending on your model and issue. The portal also allows you to upload images or videos that will assist us in repairing your product. You can also select how you wish to be notified of the progress of your repair. The portal's service history section allows you to view all services that have been performed on any of your camera or video products since January 7, 2020.
Please follow the link below to access our online repair portal to arrange for service:
https://mycanon.usa.canon.com/signin
Instructions for Accessing and Using the Online Repair Portal.
You will need to access or create your My Canon Account.
If you already have a My Canon Account and your product is already registered, simply click on the “Get Repair Services” link on the left menu and follow the onscreen instructions to arrange for service for your product.
If you have a My Canon Account and your product is not registered, you must register your product first. Click on the “Get Repair Services” link on the left menu, then click on the “Register Product” link on the right. After your product is registered, click on the “Get Repair Service” link on the left menu and follow the onscreen instructions to arrange for service for your product.
If you do not have a My Canon Account, you will need to create one. After you create your account, click on the “Add Product” link to register your first product. After your product is registered, click on the “Get Repair Service” link on the left menu and follow the onscreen instructions to arrange for service for your product.
Once you have completed the repair request, you will have an opportunity to print a copy of the request for your records. This request form will also contain shipping instructions and an address label that you will attach to the outside of your shipping box when mailing your equipment for repair.
