03-06-2025 12:29 PM
Thank you for any help!
Recently, I purchased an eos r7 to record/photograph overhead videos/pictures. Because of the orientation of the camera on the overhead stand/mount, the videos/photos are upside down. Is there a way to change the video/photo orientation before taking the video/photo? If so, does the change work for both video and photography? Thank you
03-06-2025 01:56 PM
You can turn auto rotation off, but the only other settings affect playback only. Of course it is trivial with most processing programs.
03-06-2025 06:12 PM
In the playback menu there is an option to rotate the video - this just sets a marker in the file that the video needs to be rotated.
03-07-2025 09:39 AM
Thank you. I will be using Streamlabs to record. Does this mean I need to record to the sd card, rotate the playback to Streamlabs? Was hoping to avoid the sd card. (Sorry if my 'logic' is gibberish, I am very new to all of this.) Thank you for your help.
03-07-2025 12:23 PM
You need to see if streamlabs can rotate it
