EOS DSLR & Mirrorless Cameras
4K Dual Pixel CMOS AF for Canon RP
Hello ,    I have a Canon eos RP and it is  annoying when I shoot in 4k .  Dual Pixel CMOS AF  missing  instead of eos R wich has the same CMOS digic8 sensor. It is a hardware or software limitation?   It is possible for Canon to fix this issue in th...
Mirror Lockup on Rebel SL3
This is the Rebel SL3 with a Canon ERS 18-55mm lens wth AF and Stabilizer On mounted on a tripod. Firmware Ver. 1.0.3. With either of the following two modes, Av or Tv, using the rear screen menu on, the mirror can be heard going up and then a very l...
Switch to AF L . What does this mean
In an attempt to fix another issue I am having with my 5DS-R, I dowloaded and installed the latest firmware from The Canon site.  Something went wonky during that process and the camera was not responding correctly.  So, I installed the latest firmwa...
tdehan by Enthusiast
  • 2546 Views
70D Not Coming On
Hello, friends! I'm currently traveling on the road with my Canon 70D and kit lens. I've had my 70D for several years now without any issues. However, the other morning, I went to take some photos here within the Virginia Wildlife Management Area to ...
60D settings issue
Greetings,I have a Canon 60D that is approximately 8 years old.  Recently, I've noticed that my camera settings seem to be changing, or reverting on their own.  I shoot in manual mode.  What I'm seeing is that after changing the settings to, for exam...
NisiGirl by Apprentice
  • 3822 Views
  • 2 replies
Eos R5 evf white vertical line.
Hey guys I turned on my R5 this morning and look through the evf only to find a thick white vertical line going through the left side of the evf. Is there anything I can do to fix this. I assume this something that has to go back to canon. Camera is ...
Camera won't turn on - Canon EOS Rebel T6
I have a Canon EOS Rebel T6 and it stopped working. I was taking a picture and it just shut down. Im not sure why but now the screen wont wont turn on. Ive already tried taking out and reinserting the battery and the sd card, the battery, and even th...
lluks by Apprentice
  • 39896 Views
  • 8 replies
Canon M50 Stereo input via 3.5mm Jack
Hi,Just bought an M50 camera after reading that it has a stereo input and you cand feed in it a left and right independent tracks after reading the response of shadowsports at this topic:https://community.usa.canon.com/t5/EOS/Is-the-mic-input-stereo-...
nark by Contributor
  • 15390 Views
  • 8 replies
R6 Rest / Lag Issue
I have both an R5 and R6.  Sometimes I use them both covering events and love them both.  I updated my firmware last night and was using both cameras today.  New issue I am having is when I was using the R5 and then wanted to switch to the R6 there i...
Resolved! T7 images black
I was shooting yesterday in manual mode and images were fine. Suddenly the images were all showing black. I have tried different modes, exposures, removing battery, resetting, on/off, changing lenses. The shutter doesn’t appear to be stuck. Any thoug...
Jlingo by Apprentice
  • 7316 Views
  • 2 replies
Resolved! EOS R5 How to Configure Dual Memory Slots
I've just received my Canon R5 and cannot figure out how to configure the CFexpress card to store Raw and the SD card for JPG's? It keeps storing them together and I can't understand the printed manual or the expanded PDF manual? I have a 128Gb CFexp...
