when i take photo with my Canon 5D markll it is showing line in the photo
took some photo with my Canon 5d mark ll and it showing line running thur it
Hi What kind of autofous settings do you prefer to photograph flying birds with Canon EOS 7D ? There are plenty of options there...what do you use ? What do you recommend to try ? What kind of metering modes do you suggest for flying birds ? Center-...
EOS 60D - the LCD is leaking on the LCD panel. What is the cost of getting this repaired?
I have a mac, but i can use a VM for PC. I have a 5d II and i forget what i can use to check actuations
I've recently sold all my entire Nikon gear for various reasons. I will buy the Canon 6D when it comes out next month. I currently live in Japan and it's currently listed as a kit: EOS 6D EF24-105L IS USM. I want a 18-200 and hope that Canon mat...
My T2i stops filming after a minute or less. I have it on 1280 x 720 and I have a 16GB SanDisk ultra. Help!
My Canon 7d starts to blink busy after taking three pictures in a row. The screen says busy and the red light is flashing. Any ideas what causes this?I've reformated the CF card and tried using other cards but the same problem happens. I've reset t...
I downloaded the big 7D firmware update and now my integral (or pop-up) flash will not open. I tried resetting to default, but it didn't do anything. Strangely enough, when in the function menu, I cannot change any flash settings...it says my exter...
What is best setting for video on 5d MKII? Does camera automatically focuses for moving subjects or do we need to keep focusing manually? Thanks.
Is the eos 7D a full frame?
I am looking to purchase a Rebel EOS DSLR. My question is will my lens from my Rebel EOS 35mm fit the DSLR?
is there any other issues other than lens to camera communication which can cause the err01 code to appearas I have cleaned the contacts and it works fine for a while then plays up and locks me out. The other lens there is no problem
Subject | Author | Posted |
02-22-2025 02:00 AM | ||
02-21-2025 02:01 PM | ||
02-19-2025 09:29 AM | ||
01-28-2025 01:26 AM | ||
01-27-2025 10:33 PM |
