04-20-2019 04:17 AM - edited 04-20-2019 04:18 AM
Hey folks!
I recently bought a Canon m50 and I absolutely love it. However, now that I'm about to transfer my photos to my computer it won't work. I have heard of the wireless transfer method, but in order to do that I have to connect to the camera and will therefore not have any internet connection while the transfer is being made. If this is the only way to do it I have to say that it would be a huge bummer.
I want to transfer my photos simply by a USB cable, but for some reason my laptop won't recognize the device? Also, no photos can be found if I put in the SD card into the laptop. Whenever I have a cable from my camera to laptop, the camera screen will freeze.
Do anyone know a solution to this?
Thank you in advance!
06-05-2020 02:45 PM
I finally got this to work - it's all about using the right USB cable. I must have got the one that came with the camera mixed up with the other dozen USB cables I have, and I suspect they were all not USB 2.0 cables. So use the right cable!!
04-21-2019 12:24 AM
amicyberspace,
We are sorry to hear that this happens. If you wouldn't mind, can you let the community know what operating system is running on your computer at the the time this issue occurs? Are you able to review the images you have taken on the camera itself?
08-24-2019 08:39 PM
04-25-2020 07:09 PM
I just bought a canon m50 and I also cannot connect to my pc. I have windows 10 and i have wifi turned off on it yet i don't even get the camera connected icon on the screen that i keep seeing people talk about
02-14-2020 06:29 PM
I'm having the same problem
02-16-2020 09:56 AM
04-28-2020 12:52 PM
Where you able to fix this problem? I'm having the same issue.
Thank you
05-31-2020 05:53 PM
+1. Disabled WiFi and NFC in camera. Windows 10 up to date. Tried without a memory card. Tried different cables. Same issue on my laptop and desktop PC. Device Manager shows nothing. I'm starting to suspect the USB port is broken in the camera - if a cable is connected, pressing any button in the camera simply shows "busy" on the screen. Is there no way to manually install a driver?
07-20-2020 06:22 AM
Thanks, You helped me!
The cable was wrong. (There are many cables for charging devices, whituot data lines.)
06-05-2020 02:45 PM
