Where to download EOS Utility 2
LuciWright
I have a Canon EOS Rebel T3i.  We recently upgraded from Windows 10 to 11 on our computer and my EOS utility seems to have disappeared.  I looked online and downloaded EOS 3.20 from the Canon website, but it's still not working with my camera.  A message pops up that says to load Utility 2, but I'm not able to locate that on the Canon website.  Any suggestions?   I'm  not able to download my photos in the meantime.  Thanks!
2 ACCEPTED SOLUTIONS
You do not need the EOS Utility to download images from your camera.  You can connect the camera to your computer and open the camera's storage in Windows explorer.  Images can be selected and copied from the storage media to your computer.  The same as copying files from a mass storage device.
Another option.  By a card reader.  You can use a card reader to download images from your camera's media card.  This might be the best method given the age of your camera and your newer operating system.
A third option.  On your C: drive navigate to Program Files > EOS Utility and look for a folder  called EU2.  Look inside this folder.  If present, This will open v2 of the EOS utility on your computer.
Right off hand. I don't remember which version of the EOS Utility Canon stopped, including EU2, but there's a good chance version 3.20 still has it.  You can launch it from the EU2 folder.
Let us know if you run into any snags.
For future, downloads for the T3i are available here.
Canon Support for EOS Rebel T3i | Canon U.S.A., Inc. https://share.google/HROIUbwb12aLpzqSv
8 REPLIES 8
Thank you, Rick.
I appreciate your replying & also giving me several options.  I have the original disc that came with my camera, but my newer computer no longer has a disc drive.  I was trying to figure out how to do this without buying another separate disc drive that I don't really need.
I'll try 1 or more of your suggestions & hope that I can do it.  I'm only moderately tech savy, but will give it a go.
Thanks again & Happy New Year.
Luci
Thanks, I'll keep that in mind.  I tried option 3, but it didn't work.  Will try 1st option tomorrow.
Luci
Rabbits27
Did you find a solution that worked for you?
Yes, thank you very much for checking.  I did it once & it worked well.  Now I just have to remember how I did it, but I've copied the directions.  I appreciate this forum!
The solution to the problem is even easier than the one by Rick. Getting a copy of the software using a memory stick i also not easy (any more). There are more solutions shown on internet in other communities, of which some are difficult and do not even work. My PC crashed last week and I was able to recover Utility version 2 using the Canon update and making a small change to the register. This is much easier than the above solutions..
Select your camera and download "EOS Utility 2.14.20a Updater for Windows" (yes, we will do full install with this file).
Before we can run the installer we need to add a key to our registry.
Open a commandprompt as admin and run this to create the right key for a full install.
REG ADD "HKLM\SOFTWARE\WOW6432Node\Canon\EOS Utility"
Now you can run "EOS Utility 2.14.20a Updater for Windows" to make a full installation.
Succes,
Louis
Source: https://gist.github.com/YoSoyPhil/58416dfbab8c604ed2059cd5c2469812
Thank you very much!  It's good to have several options.  I confess that I've been downloading pics from my phone most recently, which is very easy.  However, the camera does take better pictures overall.
Friends and Family
