01-28-2023 06:41 PM
I've tried multiple times to update the firmware on my R5. I have fully charged batteries, the dial on "P", a brandnew, freshly formatted SD card, downloaded and extracted the file from the website, but it on the top level of the card (verified the .FIR file is there), and properly ejected it from my PC. When I load it into the camera, and try to update the firmware, I get the message "update file not found". I tried with 2 different memory cards, always the same result. After this, I have to remove the batteries from my camera to reset it. Any idea what I'm doing wrong??
01-28-2023 07:18 PM
Is the update file on the card you have specified for playback?
01-28-2023 07:45 PM
Hi, thank you for responding. I'm not sure I know the answer to that. What do I need to check for that?
01-29-2023 12:13 AM - edited 01-29-2023 12:15 AM
@Lieve wrote:Hi, thank you for responding. I'm not sure I know the answer to that. What do I need to check for that?
Page 746 of the advanced users guide will show you how to set up your cards for various recording options. I've attached a screen shot from the manual that that will give you a quick way to check to see which card is set to Play. More than likely card 1 (CF Express) is set to play. But, TBH, I don't remember what default is because I have my cards configured to "Multiple" and set to duplicate (I have Raw on both cards).
I have card one set to play and use card 2 (SD) to transfer files to my computer. Once safely on my computer, I delete and format card 1. I also use card 2 (SD) to update firmware.
This is the folder option menu, but it shows you your Record/play selections.
Newton
01-29-2023 12:53 AM - edited 01-29-2023 12:55 AM
I would try to update from the phone instead using Camera Connect.
01-29-2023 08:16 AM - edited 01-29-2023 08:17 AM
One, when I perform updates on camera bodies with two card slots, I remove the card from the slot that does not contain the firmware update. I want only one card in the camera, and that card will contain the update.
Are you installing the correct update for your camera’s country of origin? We have had posts where forum members could not install an update they had downloaded from Canon USA. When asked, these members reported they did not purchase their cameras from the US market. They had purchased them elsewhere.
When instructed to download the firmware update from the Canon web site for their country of origin where the camera was purchased, the installation went through smoothly.
01-29-2023 09:18 AM
This ^^^^ What Waddizzle said. This is my method when updating FW. I just pop my CF card out for the 8-9 minutes a FW update on my body takes. 📸
01-29-2023 04:37 PM
I've never had a problem leaving card 1 in while using card 2 to update firmware. Obviously, it's no big deal to pop out the CF, but I haven't found it to be necessary for any of my cameras with dual slots 🙂
Newton
01-30-2023 03:15 AM
I downloaded firmware 1.7.0 for R5 from the UK, USA, Singapore and Asia web sites. The files are bit-for-bit identical, so it seems this is not an issue for the R5, at least. (It may well be for other cameras, like the Rebel/Kiss line.)
I'm baffled as to what the issue could be; R5 updates have always been effortless for me. I've never bothered about what is the "playback" card or whatever.
01-30-2023 06:54 AM
I bought my camera from B&H in the US, and downloaded the file from the US support site. I also only have one card in the card slots.
