08-23-2026 07:52 PM
Greetings, I have recently acquired a Canon EOS R. The highest jpg resolution I can set is 3888x2592, but the manual shows the higest res as 6720x4480. Is this due to a SD card issue, a firmware update, or a defect? Or??The camera works flawlessly, but I'd like to get the highest res possible. Thanks in advance.
08-23-2026 08:02 PM - edited 08-23-2026 08:05 PM
You are seeing this maximum resolution because you have the camera set to crop mode or have an APS-C lens mounted.
This is not a problem with the camera. It's firmware, your SD card, etc. If this is a new to you camera and you haven't already performed a reset of its settings, I recommend you do so.
Here is a link to the EOS R user guide which you should probably have a copy of too.
eosr-ug9-en.pdf https://share.google/RBXWK1mE7F33oDnOp
08-23-2026 09:35 PM
minref,
Go into your menu system and look for image quality. Make sure it's set for L and not M.
Steve Thomas
