02-03-2024
11:05 PM
09:46 AM
I am asking this just out of curiosity.
I don't own a camera that has IBIS.
I have read many people who recommend that you should turn off the image stabilization on your lens when using a tripod.
What do people say about cameras that have IBIS?
Steve Thomas
02-04-2024 07:14 AM
You should disable Image Stabilization when using a tripod.
Some combinations of high performance DSLR camera bodies and EF lenses will do it automatically, regardless of the swith settings on the lens. I would expect this to also be the case with R series bodes and RF lenses.
02-06-2024 12:13 PM
So far, from my own limited experience, I have not bothered to turn off IBIS in my R-series bodies and seen no problems. I am using R5, R6 and R6II units with 14-35L, 24-105L, 100-500L, 24-240 RF lenses, I also shot, using the EF-RF adapter with the following EF lenses: 24-105L, 70-200LMkII f/4, 70-300L, 100-400LMkII and the Sigma 60-600s. I cannot answer for other body/lens combinations.
02-06-2024 02:40 PM
My experience has been the same as Trevor's, I just don't bother to turn IS off on the lens. But I did the same with my DSLR's. I use L glass, so as Waddizzle mentioned, it may be being taken care of in the lens.
Newton
02-06-2024 02:52 PM
The R5 has an IBIS High Resolution Shooting mode and the manual says to mount camera on a sturdy tripod. It is IBIS only and disables IS mode.
02-06-2024 03:38 PM
@jrhoffman75 wrote:The R5 has an IBIS High Resolution Shooting mode and the manual says to mount camera on a sturdy tripod. It is IBIS only and disables IS mode.
I would suspect the R3 might do something similar. It would be consistent with how the high end DSLRs worked with certain high performance lenses.
02-06-2024 04:18 PM
That's referred to as "pixel shifting" and I can totally see why ILS would be disabled when using it. The sensor is shifted to 9 different positions using IBIS tech to take the shot, so there can't be any chance of interruption/movement during recording of the image, including your subject.
Newton
02-06-2024 04:23 PM
If high-end cameras automatically disable IBIS when mounted on a tripod, doesn't that suggest that you should manually disable IBIS when using lower-end models?
Steve Thomas
02-06-2024 04:25 PM
I don't recall disabling IS at any time on my T7.
02-06-2024 04:26 PM
Lower end models don't have IBIS. The camera that I think lies in a grey area is the R7 which has a less sophisticated form of IBIS. Canon Japan have apparently said as much.
