EOS 5D Mark II Serial Number won't work for software download
mergus
I have a 5D Mark II and I'm trying to download software but my serial number is being rejected. I can't see the bottom of my camera because I've got a Wimberley plate attached that I don't want to take off. The EXIF data in Lightroom gives me nine digit serial number but that doesn't work. Any help would be appreciated!
p4pictures
Canon camera serial numbers can start with a zero, so try adding a zero in front of the 9-digits you have.
Alternatively if you can share an unaltered image from your camera using dropbox or google drive then I can take a look at the serial number for you with the Canon DPP software. All I need is a camera original small JPG image, can be a black frame with the lens cap on.
Brian
5 REPLIES 5
Peter
10 digit serial nr is what I see from some 5D II.
LeeP
Mentor
Mentor
I had to Google "Wimberley plate" but unless I'm not seeing the right one, it seems that taking it off and putting it back on is simple and not time consuming.
Lee, I have the Wimberley II gimbal and different sized (length) plates, made by Wimberley, for each of my long lenses. The system is made so it can be balanced by the user by adjusting pivot points and by sliding the base plate, which is an Arca Swiss design. By balancing, you can move even the heaviest rig with a finger and it will stay in the last position you left it or have it return to the level position when you let go. Another advantage to a gimbal, and not just the Wimbeley system, is your rig will stay level, particularly when you are shooting video while using a suspended and hand-held device. I suspect that this is why the OP is hesitant to remove the plate. It can be a PIA to re-balance it, I mean, not awful, but it does take a few minutes of trial and error.
@mergus
Since I don't keep the plates attached to my cameras or lens feet all the time, I use a small piece of white surgical tape (it's waterproof) and mark it so that it's easy to line up the marks for each lens or camera. I can re-balance any of my rigs in a few seconds.
Take a small piece of tape, one for the camera and one for the plate, put some alignment marks on the tape, remove the plate so you can see your s/n, reattach the plate using the alignment marks.
Newton
Makes total sense now.
p4pictures
Brian
Holiday
EOS R3 - Version 2.0.0
EOS R1 - Version 1.2.0
EOS R5 - Version 2.2.1
EOS R5C - Version 1.1.1.1
EOS C80 - Version 1.0.3.1
EOS R7 - Version 1.7.1
EOS R10 - Version 1.7.0
EOS R8 - Version 1.5.0
EOS R50 - Version 1.4.0
Powershot V10 - Version 1.4.0
Powershot V1 - Version 1.1.0
EOS R50V - Version 1.1.1
