Replacing broken shutter EOS 1V
Sanchofilm
I got two EOS 1V and unfortunately the shutters have gone bad on me.  Given this is a discontinued camera. Does Any one know where I can get this serviced properly?
Thank you for the help.
13 REPLIES 13
jrhoffman75
Where are you located?
Michigan
jrhoffman75
camera repair shops in Michigan
This search in Safari brought a number of hits. Maybe another forum member has experience in that part of the country.
I searched all over Google and called. No one In Business has experience or wants to take this model of canon
jrhoffman75
Try Keh Camera in Atlanta and Hunt Photo in Melrose Massachusetts.
ebiggs1
Where to get it serviced or repaired isn't the problem getting the replacement shutter just might be however. You may be in a mail order situation for the repair and may only be able to get a used shutter assembly. After all that is a 25 year old camera and I suspect around $500 bucks to do it.
EOS 1DX and many lenses.
wq9nsc
With shutter failure, these are likely both high use bodies.  What does the film roll count show for lifetime usage?
If you want to stay with this style film body, I would seriously consider looking at ebay where they have a number of 1V bodies with low roll usage counts which would probably be a much better deal than replacing just the shutter assembly on a high usage camera body.
Rodger
Sanchofilm
First one was 600 rolls and 2nd was only 96 rolls.
Sanchofilm
My 2nd canon 1v so f as this only doing this. But I suspect this thing over exposed line is just a prelude to blade failure
