05-19-2024 04:42 PM
Hi All,
When shooting video on the R7, I would like to quickly switch between the normal shutter speed to slo mo.
Currently, when in video moode, I go to Menu/1/High Frame Rate and set it to Disable (59.94) or Enable (119.9). I would like to customize a button, or something, to allow me to quickly change between the two settings without going through the menu. I could not figure out how to do this with the instructions in the manual.
Is this possible? If so, please send a link or something to get me started.
Thank you.
05-19-2024 11:58 PM
I’m not sure you can program a button to switch frame rate and shutter speed. The solution is to use a custom mode C1/C2/C3.
You would configure the custom mode with the relevant shutter speed and frame rate then simply turn the mode dial to switch between settings while in video mode.
05-20-2024 10:25 AM
05-19-2024 11:58 PM
05-20-2024 10:25 AM
Using C1 and C2 seemed to be what I needed. Thanks very much.
