04-06-2021 02:20 AM
Hello! I just got the R6 and I'm pretty stoked about it. The ES (being silent) is a godsend for my job. But I can't seem to get it to shoot one shot - each time I press it goes on and takes 2-3. And that's obviously not ideal. I tried binding switching the drive mode to a button - but that's still too slow to be useful. Maybe someone here has some suggestions?
04-06-2021 07:58 AM
It sounds like you have the drive mode set to high speed. You can set it to single shot.
Or practice 🙂 I shoot primarily sports and leave my 1DX II and 1DX III in high speed drive mode but most game exposures are single shot. It just takes a little practice to trigger single shots in high speed drive mode.
Rodger
04-06-2021 10:55 AM
Yeah, I know about single shot. Guess I'll have to try and train myself...
04-06-2021 11:05 AM
It really gets easy after you use it for a short time AND it keeps you alert and on your toes 🙂
For sports, I have to keep my cameras in high speed drive but I don't want multiple images when one is all that is needed/wanted.
Between three soccer matches over the weekend, I shot just under 1,000 images with my 1DX III with it set for 16 FPS. The longest sequence I shot was 9 images of a keeper going down and first nearly getting trampled and then almost kicked in the head while he wrapped up the ball. The time when I get the most unwanted images is catching headers in soccer where timing is critical and most of those are 3 or 4 frames.
I accidentally shot a really long sequence while shooting U.S. rules HS football last week using three body/lens combos and in the middle of an interception while grabbing my medium range setup the 1DX III portrait orientation shutter release ended up against my camera harness and I got 30 lovely images of nothing with that body 😞
Rodger
04-06-2021 12:51 PM
@Makverus wrote:Yeah, I know about single shot. Guess I'll have to try and train myself...
You should be able to dial in a maximum frame rate when using Continuous Drive mode.
04-06-2021 12:53 PM
That would be awesome, but where is that option? Or are you just saying that they SHOULD have such an option?
04-06-2021 12:58 PM
@Makverus wrote:That would be awesome, but where is that option? Or are you just saying that they SHOULD have such an option?
It is a real setting. Even the entry level cameras have it available as a menu item. Look in the AF menus.
04-06-2021 01:03 PM
I checked there twice, but no luck...
04-06-2021 01:19 PM
Is this just for the R's? This is certainly not an option for the Rebels, or at least my Rebel T6S.
04-06-2021 01:21 PM
I don't see it on my R6, so... I may be dumb and completely miss it, though.
