03-02-2025 09:27 AM
Hello! Maybe someone can help me to set autofocus of my R5m2 to work ONLY WHEN AF-ON BUTTON IS HELD, like it worked on my previous 6Dm2 (including Live-View mode). The problem that R5m2 autofocus is working constantly, even when none buttons is pressed, in any mode One-Shot/SERVO. The only option to turn it off - AF-MF switcher on the lens, but I want my autofocus to be in standby, waiting for AF-ON button to be pressed.
I tried to find that in menus/manual/internet and found nothing ;(
Thanks in advance!
03-02-2025 11:55 AM
Check and see if Preview AF is set to disable. This will solve this problem. If its set to enable the lens will keep focusing regardless of you pressing the AF-ON or * Button. By default its enabled from the factory.
03-02-2025 11:20 AM
Hello!
I’m sorry to hear that you’re having trouble with your camera. To help the community assist you better, we need a bit more information:
- Which lens(es) have you tried?
- Are you seeing any error messages?
Any additional details you provide will help the community better understand your issue.
If you are in the United States and need urgent support, please call support at 1-800-OK-CANON (800-652-2666), weekdays from 9:00 AM - 6:00 PM (ET).
If you are outside the USA, please click HERE to find support options for your country.
Thank you, and have a great day!
03-02-2025 11:55 AM
03-02-2025 02:02 PM
relictross,
Go into your AF Menu and see if your Continuous AF is Enabled. If it is, try disabling it.
Steve Thomas
03-02-2025 02:05 PM
In newer cameras such as the EOS R10 and EOS R5 Mark II that function has been renamed to "Preview AF" now.
03-02-2025 02:48 PM
Demetrius,
You're right. I was looking at the Manual for the R5.
Steve Thomas
03-02-2025 04:10 PM
Oh Sir! Thank you very much! You made my day. I was struggling whole week and kept skipping that option all that time... I can't believe how I failed that much 😬
Have a great light and happy shooting!🌉
03-02-2025 04:12 PM
Thanks for the reply! The solution was very close, but somehow I couldn't recognize it 😪
Have a great light, Sir!
