12-28-2022 03:44 PM
I cannot seem to get the movie timelapse to work. It starts fine, but randomly stops after some number of images, and the movie is not saved. I can stop it manually (by pressing the exposure button) in the middle and it finishes and saves ok. I have done a lot of trial and error on this over several days but it just doesn't seem to work. It's very frustrating because sometimes it can go 2-3 hrs into a 5 hr timelapse and it just quits. Other times it will stop quickly after 5-50 frames. It seems completely random. Regular movie mode (non timelapse HD, 4k, 8k) work as expected.
I have tried multiple cards, Canon batteries, settings. Long exposure, short exposure, short interval, long interval. 1st frame exposure, adjust exposure. Format card, low level format, etc. Battery power, external power. Airplane mode, etc. HD and 4K settings, regular frame rate, All-I. Firmware is up to date, did not work on previous version either.
Does anyone have ideas on what else to try or is this feature just plain broken? Or maybe something else in the camera is not working? Has anyone gotten this to work?
12-29-2022 12:35 AM
Welcome to the forums. Sorry to hear that you’re experiencing issues with your camera.
Help someone to help you. Could you provide more details about the time lapse settings that you are using, so that someone can try to reproduce your issue? Please be sure to include Shooting Mode info, Drive Mode, AF Mode, etc, too.
How much available free space do you have on your memory cards when you initiate a time-lapse capture? I think you need sufficient room to capture all of the individual images?
Are you using the default power settings? Changing these settings to “force” the camera to stay powered up throughout the entire sequence may cause unexpected results. If the camera takes a nap between exposures, don’t worry about it. It has enough smarts to wake itself up.
12-29-2022 03:18 PM
Hey thanks for the reply and ideas.
Settings:
Memory cards: Tried 128 GB and 325 GB, low level and regular format immediately before trying to run the Timelapse (cards empty).
Power settings are interesting. Auto power off is Disabled, Eco mode is off, Auto pwr off temp is Standard. Not sure if there are other power settings.
12-29-2022 05:01 PM
Thanks, for the great response.
I would definitely be inclined to return “Auto Power Off” to its factory default. I think you have covered the power settings. The camera needs to take a rest, so it cannot really stay fully powered up throughout and entire time-lapse capture.
I was concerned about your exposure time running too close to your interval time. I believe the camera just blindly fires the shutter at whatever interval you set. It does not know or care about the exposure setting. This does not seem to be your issue.
On DSLRs, you had allow a minimum amount of time between the end of the exposure and the start of the next interval to fire the shutter again. This was needed to allow the time needed for the mirror raise and lower itself. On an MILC body, it would make sense force a minimum amount of dead time between shots to allow the sensor to turn off and cool itself.
I’m stumped, to be honest.
12-29-2022 07:19 PM
Thanks for the ideas and comments. Maybe someone else has something to try.
02-12-2023 02:03 PM
