R5 Mark II stops during Timelapse with low battery
radwar
I am at a loss as to why this happening. It has been lately. I am running on 1.0.3 firmware. I start the Timelapse with an interval of 30s. It takes a few shots and then it stops. If I touch the shutter release button, it says low battery change battery. I open the battery compartment, eject and put back the same battery in, it goes fine for the first few shots and then end up in the same situation.
I have tried with 4 different original *new* Canon R5 LP-E6P with the same result.
Please help/advise.
Thank you!
5 REPLIES 5
Waddizzle
You make no mention about charging the batteries.  New batteries need to be charged.
radwar
It's fully charged, by new I meant bought in the last few months,.
radwar
Any thoughts? Or is this a warranty issue?
Have you changed the default power settings?  If so, then reset it back to the factory defaults.  The camera knows how to wake itself up.
radwar
I have not changed the defaults, but sure I will give this a try. I am out of ideas.
Holiday
