Pop up flash not working
matelotmark
EOS 500D (Rebel). When I try to select built in flash, I get the error message saying not available - external flash attached, when there is no external flash attached.  The external flash works fine. Can anyone help please?
5 REPLIES 5
MikeSowsun
There is a small microswitch sensor under the hot shoe rails which senses when a flash is attached. It is there to prevent the built-in flash from popping up when an external flash is attached. It must be sticking or malfunctioning.
You could try try cleaning the  Hotshoe rails.
Mike Sowsun
matelotmark
Fixed! The micro switch was indeed stuck and I’d never have known it was there, it hidden under the plate spring where it is.
I’m very grateful for the help. Thanks
Maineman
Hi Mike,
New here and didn't find a way to post a question. Can you post here and let me know?
Thanks,
Tom
Each section has a button like this:
Thanks John
Friends and Family
