08-17-2016 10:18 PM
I want to check sharpness as I shoot on my EOS 7D Mark ii. I know how to play back the image. I know to click the index/magnify/reduce button to zoom in. But I also read where the main dial should zoom in even closer. Am I right? If so, my camera won't do it. When I spin the main dial in the playback mode it just advances to the next image. Help please!
08-17-2016 11:02 PM
On the 7Dd2, you press the magnify button once to zoom in, then use the dial near the shutter button to zoom in further.
08-17-2016 11:02 PM
08-18-2016 08:04 AM
The Main Dial is the one by the shutter button.
The dial on the rear of the camera is the Quick Control Dial.
08-18-2016 09:06 AM
@TTMartin wrote:The Main Dial is the one by the shutter button.
Pretentious terminology surely thrives in our time. I think I would've called them "the little wheel" and "the big wheel".
08-18-2016 09:29 AM
The 6D seems to combine the "little wheel" and the "joystick" into one multi-function, quick controller dial.
08-18-2016 09:33 AM
The 6D combines the 'big wheel' and the 'joystick' into the quick controller dial.
The 'little wheel' Robert refers to is the Main Dial by the shutter button.
Thus RobertTheFat, we see it doesn't matter what they are called, there will be those that confuse them.
08-18-2016 05:32 PM
My mistake. Funny, I even referenced the manual and still got it wrong. It's working now by using the main dial (the one behind the shutter button). Thanks all.
