02-26-2022 04:38 PM
No sound playback in my Canon 750D, I tried to turn the sound up! I played with it to the right, to the left? coz I am not sure which one would level up the sound.
I clicked (SET) to playback and the video is playing but without sound! why?
I didn't use the camera much! it was so good but then this happened.
The audio is working when I transfer the SD card to the laptop.
02-26-2022 05:11 PM
Arwaahmed,
On my 850D, it says that the sound volume can be adjusted with the up and down arrow keys.
It also says something about how the sound volume balance cannot be adjusted between the left and right.
Steve Thomas.
02-26-2022 08:25 PM
Kindly advise and will appreciate where is the up and down keys in the camera? what is gonna move here in the screen I adjust the sound?
02-26-2022 08:41 PM
I rotate the small wheel near the shutter button, here the photos show two wheels, one is big and one is very small, will the small one makes any difference? what should I do here
02-27-2022 05:59 AM
Your up and down, a ND Your left and right arrows are on the big wheel on the back of your camera next to your screen.
02-27-2022 06:43 AM
The small one next to the viewfinder is the Dioptric adjustment knob for the viewfinder.
02-27-2022 11:31 AM
Arwaahme,
From Camera Decision. " 750D has a built-in Stereo microphone and a Mono speaker."
During the Playback of your movie, you should see a little speaker in the bottom right hand corner of your screen. If you tap that little speaker, you should be able to adjust the volume level up or down by pressing the top or bottom of that wheel I showed earlier:
Steve Thomas
