03-19-2014 07:39 PM
I've installed the necessary software from Canon, but no luck. Any suggestions?
03-27-2020 06:47 AM
thats what I was thinking last night! though I've tried three different cables lying around the house
04-19-2020 06:15 PM
04-19-2020 06:28 PM
I'm not sure you can connect to a computer via HDMI. Have you tried with USB?
04-19-2020 07:04 PM
04-19-2020 07:32 PM
06-09-2020 07:13 PM
@TCampbell wrote:It’s easy to mistake the USB cable and use a cable that wont work (and this is probably the most likely cause).
Make sure you aren’t using a USB “charging” cable. A number of devices now use USB cables simply to charge a device and include cables that only have the power pins wired ... the data pins aren’t actually wired. If you use such a cable, the computer wont see the camera. The cable needs to have the data pins wired.
Some cameras that support WiFi wont show up if the camera is in WiFi mode ... but the T3i doesn’t support WiFi transfers so that wont apply to your camera.
This was exactly it. I tried 3 different cables and nothing worked until I unplugged the one from my wacom tablet and now it's working perfectly. Thank you!
09-29-2020 05:57 PM
I just went through the steps to determine if my Mac is recognizing my camera. It is not showing up in the USB section of the Utility Window. Can you help me understand why my computer is not recognizing my camera? This is strange becasue this is not the first time that I am connecting the camera to this computer. For some reason it just stopped working. Can you help?
09-29-2020 07:22 PM
Try running image capture from the Applications Folder
09-29-2020 08:24 PM
09-30-2020 09:05 AM
I am telling you to go into applications and run the program that actually talks to the camera: Image Capture. Sometimes it is misconfigured.
