Mark III 5D
KamdynFuller
My shutter will not open when I try to look through my Viewfinder. Please help! I can take pictures through the screen but when I switch back to the view finder, it is black.
16 REPLIES 16
Did you remove your lens and look in the mirror box?
Yes, the Shutter is closed.
When you open the camera, is the shutter exposed immediately?  If so, then your mirror is stuck in the up position.
cheers, TREVOR
It seems like the Shutter is getting jammed. I can touch it and it will come back down, but as soon as it takes a picture and goes back up it jams again.
That would be normal if the camera is stuck in back in live view mode.  If you have not done so, I would definitely do a camera settings reset.   Can you confirm that the mirror, normally in front of the shutter, is always in the up position?  Don't try to force it back down!!!!
cheers, TREVOR
I have already reset the camera settings. I did not force it back down if I barely touch it, it comes down on its own and I can finally see out of the viewfinder. Once I click the button and take a picture, it takes the picture but the shutter is closed and I am no longer able to see out of the viewfinder.
Looks like you need a mirror box repair.
Friends and Family
