M50 Mark 2 . Focus issues
Harped90
Hello I'm new to cameras I recently purchased a M50 mark 2. Camera worked great took a few picture everything was clear. Well I went to mess around with it some more today and tried out a different lens a vivitar 49 mm telephoto lens. Since doing that when trying to use the base canon efm 15-45mm lense it will only focus on objects directly in front of the lens. I'm talking within 1 to 2 inches.
I've initially thought I messed up the settings so I did a settings reset. I've reseated the efm several times still no improvement.Tried to clean lens makes no difference. One odd thing is when I put on the vivitar 49mm wide angle lens it goes back to normal.
I'm hoping I'm making some simple rookie mistake any help would be appreciated. Two pics included one with the efm 15-45 mm and the other is the efm 15-45mm + the vivitar 49 mm wide angle lens
Waddizzle
It almost sounds like there might be multiple “lens filters” in use at the same time.  If you use a UV filter on the lens, then remove that one, too.  It might not be the UV filter.
Make sure all filters are removed from the lens, and test it again.
14 REPLIES 14
Harped90
Tronhard
Hi, sorry to learn you are having issues.
It might be worth checking to see that the camera has not been set to manual focus mode by the Vivitar lens.
cheers, TREVOR
"The Amount of Misery expands to fill the space available"
I checked that it's not the case. Thanks
kvbarkley
VIP
VIP
Does the lens retract/extend when you turn the camera on or off?
The lens does have a switch to extend to use, and if it is not extended, the display is blocked by a message that it must be extended to use and it won't focus at all, so I discounted that.
cheers, TREVOR
If you mean automatically no. Manually yes
FloridaDrafter
"one with the efm 15-45 mm and the other is the efm 15-45mm + the vivitar 49 mm wide angle lens"
Are you talking about a wide angle Vivitar "filter" that you screw on the end of your EF-M 15-45 lens?
Newton
Yes exactly . It works with the wide angle filter excuse me for using the wrong language
We had this same issue with another recent thread, can anyone remember what the result of that was?
cheers, TREVOR
