What camera should i get - Upgrade recommendations from EOS 2000D
lorenma
My first camera is the canon 2000d and i have learned a lot with it but i'm ready to upgrade to my next camera. What i dislike about the canon 2000d is the slow speed in burst mode and the af-system is also slow and not really fit for my needs as it only has 9 focus points. I love doing wildlife photography and also just random stuff in general. I would like to stay with dslr's for a bit because the lenses are getting cheaper and i like the feel of them. My budget is about 600-700€ and I thought about getting a Canon 7d mark ii. Before i buy it tho I wanted to know if there were any better options that fit the same categories. Thanks in advance.
3 REPLIES 3
p4pictures
Hello and welcome to the forum.
The EOS 7D Mark II is a great camera with a fast shooting speed and a capable AF system. It will also work with any lenses you have for your EOS 2000D. It is usually only available as a used model and should be within your budget for a camera in great or excellent condition. You might also want to consider the EOS 90D but I think it will be more than 1000€ for a new one.
One other option that is on the edge of your budget is the EOS R50 mirrorless camera. I found a price of 729€ at a German photo dealer. It offers a good step up in performance with 24MP and 12 frames per second continuous shooting speed, plus you would get the extra abilities of the modern mirrorless AF system which is a significant benefit. You would need the EF to EOS R lens adapter so that any of your existing DSLR lenses can be used on the mirrorless model.
Brian
stevet1
lorenma,
If you want to stick with DSLR's, I have a Canon T8i and like it very much.
One of the concerns I had when I upgraded was the weight. The T8i only weighs 515g. The 7D Mark II weighs over 900g.
You could get the body only and use your existing lenses.
Steve Thomas
Tronhard
VIP
VIP
I had the 7DII from new for quite a while, and it was the flagship APS-C camera, with superior build, excellent focusing and a good sensor.   It was supposedly replaced by the EOS 90D, but that was not as robust, did not have as good focusing, although it did boast a 32MP sensor.  However, that tended to show noise from about ISO3200 and it was not, to me, as good a  unit.   If the 7DII is in good condition then I think that is a good option.
Alternatively, the last of the DSLRs to be released is the EOS 850D (T8i in North America), which was a slight step down in build quality from the built like a tank 7DII, but it does boast an articulating screen and excellent focusing system without the noise of the 90D because it has a 26MP sensor, which seems to sit in a sweet spot for APS-C sensor cameras as regards noise.  That will likely also be supported for service the longest.
cheers, TREVOR
