09-11-2021 05:13 AM
I bought an EOS R with battery grip. I found out so far, that I only can charge the accus inside the grip using the AC adapter which was sold with the grip. No other adapter / laptop / powerbank works. This isn't really helpful.
My son bought an EOS R5 and the battery grip. There was no AC adapter included with the grip and he found out so far, that only the Apple adapter from his girfriends iPhone works. This is also not really practicable.
How can we charge our cameras / battery grips from some unspecific USB source like Wall adapters, Powerbanks, Laptops (we use HP & Asus)?
I will buy a R5 or R3 soon, and there is a need to solve this issue in advance.
With best regards
Gerhard
09-11-2021 12:28 PM
If you are having trouble using USB-C to charge your camera, this video may help.
09-11-2021 09:02 AM
@Gerhard56 wrote:Hi,
With best regards
Gerhard
What is an "accus"? What brand of battery grip are you using? Canon does not support third party gear.
I do not think the Canon battery grips support USB charging.
09-11-2021 09:41 AM
09-11-2021 11:02 AM
Camera batteries can supply a lot of power, so it takes a lot to chage them. I am sure you need a high power adapter. What is your question?
09-11-2021 12:28 PM
09-11-2021 05:16 PM
I agree with KV that you will need a high power adapter for charging.
In many countries, rechargeable batteries are referred to as "accumulators" and I suspect that is where poster's abbreviation "accus" originated.
Rodger
09-12-2021 03:16 AM
09-12-2021 09:41 AM
No need to apologize for using the term!
I became familiar with it when I bought a Grundig shortwave radio while I was lecturing and guiding a group of study abroad students at Paderborn University 25 years ago. That Grundig radio drained the accumulated charge very rapidly from its batteries but it was far better than paying for disposable batteries when using it away from AC power.
Rodger
09-12-2021 01:23 PM
@MikeSowsun wrote:If you are having trouble using USB-C to charge your camera, this video may help.
I see you selected my video link as a solution to your charging problem. Can you tell us what part of the video was the solution? It may help others with the same problem.
09-12-2021 02:39 PM
