01-19-2022 03:37 AM
Camera EOS Rebel t6s
I use two cameras. One is Canon Rebel T6s. I always take the battery out of T6s camera for charging. But for the other camera, I always charge its battery in the camera every time after down loading the the new images. Can Rebel T6s do the same? and does it cause any issues?
Thank.
01-19-2022 06:32 AM
The manual states that you need to use the charger (page 32). Note that Canon's support page for the T6s doesn't provide a link to the manual, but I was able to do an internet search for it that found it on some documentation web site.
You also mention two cameras. Are they both the Rebel T6s? I only see one camera model listed in your question.
01-19-2022 08:43 AM
Ricky answered, but just to let you know, the T6s battery has too high a voltage and requires too much current to be charged by standard USB.
01-19-2022 10:43 AM
Not only the correct cable but into a USB port that supplies 5V/2A power. There isn't anything special about the Canon USB cable except it is the correct wire gauge for charging. Cheap cables may not be.
01-19-2022 10:55 AM
The manuals for the EOS Rebel T6s can be found on the Canon USA page here: https://canon.us/3IakijU
I'm not a tech, however, the Rebel T6s cannot charge using the USB cable. You must use the external battery charger.
01-20-2022 07:01 AM
Thank you.
Yes. The manual says battery is charged with the charger that Canon provided with the camera.
The other camera is a Sony a7II. I do not have any digital lens for this camera. I bought it for using my old mechanical lenses. I did not want to mention it on Canon Forum.
01-20-2022 07:06 AM
Thank you.
I have a manual, downloaded. It is clear in the manual the battery is charged with the charger which came with the Camera. I am kind of lazy. That's why asking.
01-20-2022 07:13 AM
Thank you.
For safety, I'd better stay with what the manual ssys. The bad thing about charging with the charger is that I sometimes forget to charge the batteries and thus ruin them.
01-20-2022 07:17 AM
Thank you.
I'll stay with what the manual says, charge the batteries with the Canon Battery Charger.
01-20-2022 09:59 AM
I did not think your camera could be charged with the battery in-camera but I was not sure. Stephan cleared that up. The ones that do have that feature need to have the proper cable was my point.
