02-23-2023 11:34 PM
Hey all,
I have a pretty peculiar issue going on with tethering my 1DX Mark II to both my MacBook Pro M1 Pro and my iPad Pro M1. When I connect the camera via a Tether Tools micro B to USB-C cable to either of the devices, none of my software will connect to the camera (EOS Utility 3, Lightroom, CaptureOne -- this will actually recognize, but throw a timeout error). It's basically the same story with my iPad Pro M1.
These combos work:
- Use a Tether Tools micro-B to USB-C cable connected to Apple Studio Display and use that as a hub.
- Use a generic micro-B to USB-A cable plugged into a Targus USB-A to USB-C hub connected to the studio display.
These combos don't work:
- Use a Tether Tools micro-B to USB-C cable connected directly into the MacBook and iPad.
- Use a generic micro-B to USB-A cable plugged into the Targus USB-A to USB-C hub connected directly to the Macbook/iPad.
- Use a generic micro-B to USB-A cable plugged into a USB-A to USB-C adapter connected to the Macbook/iPad.
- Use a generic micro-B to USB-A cable plugged into a USB-A to USB-C adapter connected to the Studio Display.
Basically, for the most part, whenever I plug it directly into the MacBook or iPad, my software doesn't detect it. It only works when plugged into the Studio Display.
Mac OS's System Information app shows that a Canon device is connected to the USB-C ports, so Mac OS is detecting it when it's plugged directly into the laptop.
I don't have any issues if I were to plug it into my 2019 MacBook intel i7 that I got from work. That laptop is on Big Sur.
My personal laptop specs are:
14" MacBook Pro M1 Pro, 16gb RAM, Mac OS Ventura (same thing happened with Monterey... I was hoping the update would fix it.)
My 1DX Mark II has the latest firmware update as well.
Any ideas as to what might be going on, and how to get my camera to tether directly to my MacBook?
02-25-2023 08:38 PM
I got it working again. I re-installed the 1.1.8 firmware, and now my 1DX II is once again connecting to my MacBook as expected.
02-24-2023 05:51 AM
In general, using USB port adapters do not work. Does not matter if you are using an Apple or Windows product. How long are your USB cables? Have tried an Apple cable, instead of generic or third arty cable?
02-24-2023 04:39 PM
The Tether Tools cable is a solid 6-8 feet long, and the generic cable I was trying is a short cable from an external hard drive that's only a few inches long. Unfortunately, Apple doesn't manufacture/sell Micro-B cables.
02-25-2023 06:08 AM
@herringburdenso wrote:It makes no difference whether you use an Apple or a Windows product. What is the length of your USB cables?
https://community.usa.canon.com/t5/EOS-DSLR-Mirrorless-Cameras/Issue-tethering-1DX-II-to-MacBook-M1-... doodle jump
OP already stated that.
02-25-2023 08:38 PM
02-26-2023 06:56 PM
@corbinwesler wrote:I got it working again. I re-installed the 1.1.8 firmware, and now my 1DX II is once again connecting to my MacBook as expected.
Congratulations! I am glad to hear you got it working. However, I doubt updating the camera firmware had anything to do with it. The update and it working again are most likely a mere coincidence.
