07-02-2025 02:41 PM
07-02-2025 03:33 PM
Is the camera in standard or guided mode?
Go into your menu, select Menu display usually under the first tab.
Change the setting from guided to standard, exit and then return to the menu and follow the previous instructions.
I believe you need to be in M, A or P to view all the menu options. Hopefully someone will clarify. I always go into my menu in M and have access to all the functions.
Good luck. Please let us know if this worked out.
R3 ~ R5 ~ R6 Mk II ~ R50
Lenses: RF Trinity and others
Adobe and Topaz Suite for post processing
Personal Gallery
07-02-2025 04:10 PM
What do you mean from guided to manual. You need to turn the top mode dial to M,Av,Tv or P modes to access the firmware version. It will not work if the camera is set to A+.
07-02-2025 03:07 PM - edited 07-02-2025 03:07 PM
Personal Gallery
07-02-2025 03:24 PM
Hi Marc: This is how I tried to find it and there are no firmware-related options in any of the setup folders under function settings (the wrench). Any other thoughts?
07-02-2025 03:33 PM
Personal Gallery
07-02-2025 03:39 PM
As Marc directed, after pressing the cameras "Menu" button, look in "Functions" ==> menu item 4, as shown on page 553 of the advanced users guide. You can download the manual from the Canon Support page for the EOS R100 🙂
Newton
07-02-2025 03:43 PM
Dang, I forgot to even mention that you have to be in a "Creative" mode, LOL!
Newton
07-02-2025 03:58 PM
Thanks both Marc and Newton. I changed the display from guided to manual and still no luck. I have the manual downloaded and will keep digging. It is not a pressing issue...I just noticed the firmware download on the support site and got to wondering if mine was current. I purchased it a few months ago so it should be. As I've demonstrated...I'm very much a novice. Continuing to dig will only help me become more comfortable with it!
07-02-2025 04:07 PM
The EOS R100 does NOT feature a touchscreen.
07-02-2025 04:10 PM
07-02-2025 04:17 PM
Thank you all - finally got there.
