EOS R8 Digital Lens Optimizer in High has poor write performance
arkaitz
Hello Everyone,
I´ve notice that when I set Digital Lens Optimizer to High in the Lens aberration correction menu I get really low write speeds. Is it something expected or is it a bug? I´m using a V60 SD card, without that option I can shoot in continuos mode without even getting the buffer filled so it´s unlikely to be a SD card issue.
2 ACCEPTED SOLUTIONS
Waddizzle
It’s probably normal.  I never use it myself,  in fact, I am not sure if I ever have.
What does it do?  It corrects for common distortions created by certain lenses.  It can become time consuming to perform.  Lens correction is best performed in post.
Which lenses?  Mostly third party lenses. Canon has a library of lens correction templates for their lenses.  The templates are optimized by lens, and be applied a little faster than DLO, which requires more CPU power and time.
If you’re saving your files as JPG, then you may need to allow the camera to perform use the DLO.  Most users disable it in the camera, so that they can apply it in post using a computer.
If you are saving files in RAW format, then no lens correction is applied in the camera. Lens correction is applied in post.
It is highly desirable to use Canon lenses, because the free DPP app from Canon is optimized for Canon lenses.  It’s not compatible with third party lenses, which is why Canon provides the DLO tool.
wq9nsc
DLO creates a lot of processor overhead so I suspect a lot of that time is processor loading instead of just data transfer.
I only shoot RAW and do all of that in post.  If you are shooting JPG then you need to use these options in camera but if you are shooting in RAW, then turn off options including DLO and NR and do those in post.  For me, this type of work is better suited for my HP Z series workstation instead of in the camera body.
Rodger
3 REPLIES 3
Waddizzle
wq9nsc
Rodger
johnrmoyer
I set DLO to standard in the camera because then in DPP I can see what level the camera would have chosen. If I were not using the JPG or HIF files and were editing the CR3 file in other software, then I would disable DLO. The Richardson/Lucy deconvolution to remove small aperture refraction blur and remove blur caused by the anti-aliasing filter can take a long time to calculate. It also takes a long time in the "capture sharpening" in rawtherapee. If there is high ISO noise in the photo, then the camera will reduce the number of iterations and it will take less time.
Quoting the manual for my camera:
Image processing after you shoot takes longer when set to [High] (which causes the access lamp to be illuminated longer). Maximum burst is lower with [High]. Image recording to the card also takes longer. Depending on shooting conditions, noise may be intensified together with the effects of correction. Image edges may also be emphasized. Adjust Picture Style sharpness or set [Digital Lens Optimizer] to [Disable] as needed before shooting. The higher the ISO speed, the lower the amount of correction will be. For movie recording, [Digital Lens Optimizer] will not appear. (Correction is not possible.) The effect of Digital Lens Optimizer cannot be checked on the screen at the time of shooting.
https://en.wikipedia.org/wiki/Richardson%E2%80%93Lucy_deconvolution
https://en.wikipedia.org/wiki/Airy_disk
