Help! Images taken on a Canon EOS 2000D won't display on camera and can't be downloaded
vglf
I took a load of photos yesterday using a memory card.  Half of the images are fine but the others, despite there being something there as they are all substantial file sizes, won't display or download.  It says the format is not supported!
I'm so upset at the photos were for work and I am going to be in all sorts of trouble without them.  I have tried downloading with the Canon app, also with my laptop.  How can I try to rescue the images and get them?
12 REPLIES 12
stevet1
vgif,
What are the file extensions of the files that you can't display?
What is the method you used to try and download them?
Steve Thomas
kvbarkley
What camera?
What Computer?
Do the images display on the camera?
Is it a full size card or micro with adapter?
Do you have a card reader?
How did you download the images?
They are all jpeg files…..I first tried to download them on my canon app on an ipad, then via my apple Mac using the memory card in a usb thing.  Both cards have the same problem but I know that when I took the photo it showed in the display on the camera as a ‘taken’ shot!
The images aren’t displaying on the camera but they were there directly after I took each photo.
The oddest thing is some pictures are saved and showing, just the vast majority are not.  The camera is a Canon EOS 2000D and I have tried downloading them all different ways
If you can't display them on the camera, it is likely that the memory card is corrupted. Again, was this a full size card or micro with adapter? When was the last time you formatted the card in the camera?
I formatted it yesterday before using. It is a full size card!
Can corrupted memory cards be fixed?
kvbarkley
It is unlikely, you can try file recovery software - you can check the mfg of the card's website - but usually recovery is for when you can't find any files at all, not for corrupted ones.
Other folks might have some better solutions.
Can you use your card reader and show us a Finder "get Info" display on one of the bad files?
