Focus bracketing on R6 and with a EF lens
bbbryan
I'm excited to start experimenting with focus bracketing and landscape photography. However, I came across a Canon list of lenses that are 'compatible' with this feature. I use a EF 17-40mm L lens with a Canon mount adapter. This lens is not on the compatible list.
What happens when I try to focus bracket with a lens that is not compatible? Does this mean I should move to a newer RF lens or can I still get away with using it?
Thanks!
Wandalynn
Enthusiast
I've been using the focus bracketing feature with my R5 and the RF 100mm macro for the past year. After reading your post, I randomly grabbed my EF 24mm f/1.4 L ii, put it on the R5 and took a focus bracket of 5 images just here in my office. I stacked the pictures using Canon's DPP. It worked perfectly! I'd say just try your lens--it might work. And I highly recommend using DPP for the stacking--it's a breeze. The command is called Depth Compositing--I just use it on the defaults. I also recommend downloading the DPP manual when downloading the app for additional information. I've read, however, that the focus bracketing feature is at its best when used for closeup photography. I got an RF 15-35 lens for Christmas and so far haven't been able to get such dramatic results with landscapes.
3 REPLIES 3
jrhoffman75
Even if the bult-in focus bracketing tool won't work with a particular lens you can still use the manual method or tools like Helicon Remote or Kuuvik Capture.
Wandalynn
Enthusiast
Thanks so much! And I will definitely try it with DPP.
Friends and Family
