05-07-2022 12:53 PM
The single focus point in the view finder drops slightly diagonally right from centre and needs to be corrected by pressing the trash button. Note, this happens when the touch screen is closed. I've had the camera for around 6 months and it has only just started doing this.
Any thoughts?
05-23-2022 10:35 AM
Can you describe how it happens? Does it just move on its own or does it shift when you switch to the Custom C1 mode? Perhaps the focus point was off-center when you registered the custom setting?
05-07-2022 01:03 PM
What camera body are we talking about?
Are you saying that the center AF point is no longer in the center?
05-07-2022 05:40 PM
sorry, it's the EOS R. Yes, just slightly down to the right, always the same place. It's as if I've moved it on the touch screen but I definitely did not. As I said, the screen is in the closed position.
05-07-2022 06:18 PM
Thanks, for the reply! What shooting mode are you using? What AF point selection mode are you using?
If you switch to the Green [A+] shooting mode, where is the AF point?
05-08-2022 11:24 AM
Shooting mode is Servo AF on manual, AF point selection is Expand AF area.
Green A+ is scene intelligent auto - multiple points. No idea if the same happens here but I doubt it.
05-09-2022 05:53 AM
The AF system uses an initial starting point, which is usually the center AF point. Scene Intelligent Auto behaves this way.
The Expand AF modes do not display the Center AF point. They display the Initial AF point, which can be selected automatically or manually by the user.
05-23-2022 09:19 AM
In order to explain the problem, I have attached 2 photos taken through the viewfinder. One shows the focus point centred, the other when the focus point drops inexplicably down and to the right. centred
dropped
05-23-2022 10:35 AM
05-23-2022 05:01 PM
John, I think you've cracked it!
I didn't realize that the custom setting effected the focus point too!
Many thanks
